SafeNet USB Driver for Windows 10 64-bit
sergey.churilov
sergey.churilov
Hello to all,
After quite some time I am bringing the similar issue again.
I need recommendation of the correct driver for my usb dongle. 🙂 and yes, I would like to use the old Robot version on Windows 10 64-bit. I used it on Windows 7 64-bit with success.
The problem is that I have Sentinel HASP Run-time 5.95 for Win7 which no longer works (due to compatibility issues) in Win10.
Can anyone tell me which driver can be used for the usb dongle in Win10?
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @sergey.churilov
You may want to check https://sentinelcustomer.gemalto.com/sentineldownloads/
There is also the Technical Support tab there.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
sergey.churilov
Thanks Arthur,
I already tried with Sentinel HASP LDK - Windows GUI Run-time Installer ver. 7.66 but no luck.
I guess I will ask the technical support.
sergey.churilov
No luck with the Sentinel support.
They provided me help, but unfortunately none of this is working for me.
Their final thought was to contact the vendor company 🙂
Community Visitor
Community Visitor
personal use
