Announcements
RSPRO 2015 missing tabs
Kindly please help me on this issue, the tabs were dissapeard and sometime they are visible. Many Thanks
missing tabs Structure Beam - View, Beam - Diagrams, Beam - Reinforcement, Beam - Note
undefinedundefined
Replies (13)
Rafal.Gaweda
Autodesk Support
Autodesk Support
clear cfgusr folder
then
Tools \ Customize \ Open layouts from template
Rafal Gaweda
Dear Mr. Rafal Gaweda,
I have this another issue below  when doing stirringup spacing and it giving me this error below.
Kindly advise and many thanks
Regards
By the way, the version of this robot is 2016 but on the robot 2015 it is working fine.
Regards
Regards
Rafal.Gaweda
Autodesk Support
Autodesk Support
Update your Robot with SP1
If this dialog still gives crash or is not updating reinforcement please change spacings in table
undefined
Rafal Gaweda
ledinhchinh0409
This file by me on Provided Reinforcement of RC elements for beam element loses tabs beam - diagrams, beam - reinforcement, beam - note .... Other rob structure structures are still there. I do not want to use the CfgUsr file deletion. Thank you.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @ledinhchinh0409
Please try the solution provided in this article.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
ledinhchinh0409
Thanks for the quick response. However, I still can not fix it.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @ledinhchinh0409
As far as I can see you don't have the entire viewer rather than tabs only. Could you attach this file? What is supposed to be displayed: the beam view, reinforcement distribution?
Artur Kosakowski
ledinhchinh0409
Hi. The file I've attached above. However, I was able to handle it. I followed your instructions and clicked through the old beams that had the reinforcement of RC elements, and everything was fine. Strangely, I lost the whole afternoon. Thank you very much !!!
ledinhchinh0409
Hello sir When I switch to the beam - diagrams, there is no longer a beam to beam - note ..... That's it.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @ledinhchinh0409
Each time you can't see the tabs at the top of the screen use: Tools > Customize > Open layouts from template
If one or more of these posts answered your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Artur Kosakowski
ledinhchinh0409
RSA is like a beautiful girl but sometimes angry. Do not know if I write in English right @Artur.Kosakowski? hihi.
ledinhchinh0409
RSA same as a girl girlfriend xinh đẹp but double when tức giận. @Artur.KosakowskiAnh must@Artur.Kosakowski? hihi.
Type a product name
