RSA dynamo-Optimo input
1234eddie
1234eddie
Hi all,
I’m currently trying to learn and understand how to use genetic algorithm from the Optimo package for dynamo and robot structural analysis.
As example i use the class of Dieter Vermeulen “Dynam(o)ite Your design for Engineers”(ES9542) method 'brute force search'
Below is my dynamo sheets which creates just a simple bar on three supports. The script works.
But what i don’t understand is how does the custom node “Simplebar 0_02” know what input it should use?
What i figured out is that the order of parameters in red box 1 needs to be the same order as in red box 2.
I hope someone can explain me how this works?
/or where to find more information about this method?
The files are attached in the zip.
Gr Edward
1234eddie
Got some help on the Dynamo forum
