RSA API draw polyline
1234eddie
1234eddie
Hi all,
I'm currently working on a script to draw a polyline in RSA by using a python script inside dynamo.
(i will use this line later to apply a load in it[it will be part of a panel edge])
But at the moment i can't get the script working. I get this error:
This is the function inside RSA
below my script i wrote:
import clr
clr.AddReference('ProtoGeometry')
from Autodesk.DesignScript.Geometry import *
#The inputs to this node will be stored as a list in the IN variables.
from System import Environment
user = Environment.GetFolderPath(Environment.SpecialFolder.ApplicationData)
clr.AddReferenceToFileAndPath(user +r"\Dynamo\Dynamo Core\1.3\packages\Structural Analysis for Dynamo\bin\RSA\Interop.RobotOM.dll")
from RobotOM import *
from System import Object
application = RobotApplicationClass()
project = application.Project
structure = project.Structure
labels = structure.Labels
loads = structure.Cases
objects = structure.Objects
ProjectPrefs = project.Preferences
pts = application.Kernel.CmpntFactory.Create(IRobotComponentType.I_CT_POINTS_ARRAY)
#pts = application.Kernel.CmpntFactory.Create(IRobotComponentType.I_CT_GEO_POLYLINE)
obj_server = IRobotObjObjectServer
obj = IRobotObjObject
pts.SetSize(2)
pts.Set(1, 0, 0, 0)
pts.Set(2, 10, 0, 0)
obj_server.CreatePolyline(IRobotObjObjectServer.CreatePolyline,1,pts)
OUT = 0
I hope someone of you can tell me what is should change of append different?
Thanks in advance
gr Edward
files are attached.
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @1234eddie
Here You are:
# Load the Python Standard and DesignScript Libraries
import sys
import clr
# The inputs to this node will be stored as a list in the IN variables.
dataEnteringNode = IN
# Place your code below this line
#user=Environment.GetFolderPath(Environment.SpecialFolder.ApplicationData)
clr.AddReferenceToFileAndPath(r'c:\Users\gawedar\AppData\Roaming\Dynamo\Dynamo Revit\2.3\packages\Structural Analysis for Dynamo\bin\RSA\Interop.RobotOM.dll')
application= RobotApplicationClass()
project= application.Project
structure=project.Structure
pts = application.CmpntFactory.Create(IRobotComponentType.I_CT_POINTS_ARRAY)
pts.SetSize(2)
pts.Set(1, 0, 0, 0)
objects.CreatePolyline(1,pts)
OUT = 0
Rafal Gaweda
1234eddie
@Rafal.Gaweda
Many thanks.
I didn't realize that the polyline is a part of the objects group.
I will start a new topic about a question i have when using linear load on edge.
Thanks.
Gr. Edward.
to complete this topic here is also the script with loops for multiple polylines.(file is also attached)
import clr
Points = IN[0]
Count_points = IN[1]
NR_polyline = IN[2]
for j in range(len(Points)):
	pts.SetSize(Count_points[j])
	for i in range(len(Points[j])):
		pts.Set(Points[j][i][0],Points[j][i][1],Points[j][i][2],Points[j][i][3])
	objects.CreatePolyline(NR_polyline[j],pts)
OUT = 0
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @1234eddie
See this topic and macro there:
https://forums.autodesk.com/t5/robot-structural-analysis-forum/error-2110-problem-with-linear-loads/...
Rafal Gaweda
