RSA 2025 Cable not converging (and node instability)
dndllc
Message 1 of 9
dndllc
I have a netting support design for a backstop in a baseball stadium.  The cable analysis doesn't want to converge.  I've made sure it has DL on all members.  I've tried elongation in cables at -0.01 and also putting in a tension.  What am I missing?
Node stability at 20, 27, and 14 seem to be okay now.
Replies (8)
Message 2 of 9
Simau
Hi @dndllc
Hard to say without the model.
Zip and share it
M. Agayr
Message 3 of 9
dndllc
didn't like the *rtd file.  posted a zipped file instead.  Thx for catching that.
Message 4 of 9
Romanich
Hi @dndllc,
You have to define load combinations and mark simple cases as auxiliary.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 5 of 9
dndllc
@Romanich , I added the load cases and changed the simple loading to Auxiliary,  but it is still not converging 😞  Some were much better though.
I read somewhere that I should mark the P-Delta and Large Displacement as well, so I modify that as well.
If the diameter of the cable is not sufficient, will that cause it to not diverge?
Message 6 of 9
Romanich
@dndllc
Are you sure that vertical elements also cables:
Roman Zhelezniak
Message 7 of 9
dndllc
In the real world design, it will be there to attach the net to.  The net/panel is a two-way panel.  It also seems to keep the node above stable.
I just read something that if a cable gets put in compression then it could lead to non-convergence.  Would a rod as a tension-only member work better here?
Message 8 of 9
Simau
Hi @dndllc
As @Romanich  said, if you replace the vertical cables with bars, the model converges.
No, you need a bar fixed at its bottom.
M. Agayr
Message 9 of 9
dndllc
@Simau , @Romanich Thank you for your help.  It was a combination of missed things on my part.  Between your suggestions, what I found online, and Krzysztof Wasik from Autodesk, I was able to get it
to converge. here is what was missing:
  1. Create Auxiliary load cases. (Romanich)
  2. where cables come together, create a support to prevent rotation in all directions. (I can keep the vertical cables).  (online)
  3. Mark loads with P-Delta and Large Displacements.
  4. Adjust the Non-linear Analysis Parameters. (Wasik)
    Thanks again, David
