Per ACI equation 6.6.4.5.2 delta should be greater than or equal to 1.0, Robot currently allows values less than 1 to be considered.
Also when choosing "save project as" with the Column-note tab active Robot attempts to save the model as a text document.
Solved by okapawal. Go to Solution.
the Beta,dns factor is also incorrect it should be calculated base on the ratio of dead load to total factored load.
This issue has been corrected in Robot Structural Analysis 2024 release. Release notes
Implemented condition for min delta for ACI318-14 & ACI318-19 according to p.6.6.4.5.2
