RSA 2014: Automatic verification
Romanich
Mentor Mentor
Message 1 of 12
Romanich
Is it possible to switch off automatic verification in RSA 2014? Maybe some changes in INI files and etc? Because this was a timesaver trick for advanced users.
2014:
2013:
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Accepted solutions (3)
Replies (11)
Message 2 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
I fully understand your point but this change is intentional to prevent situations where incorrect models are calculated with no information about this fact whatsoever especially when they are sent for cloud computing.
Artur Kosakowski
Message 3 of 12
Romanich
It seems that the cloud spoil the Robot...
Roman Zhelezniak
Message 4 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
That is not that simple. On one hand there are requests from users as you I know what 'm doing and I don't need these 'unnecessary' checks as they slow me down and the same time you have comments like the program should never calculate structure that is incorrect without giving me a warning. At the end of the day the development team has to make some decisions Smiley Happy
Artur Kosakowski
Message 5 of 12
Romanich
Dear Artur, do you have information from the development team?
Roman Zhelezniak
Message 6 of 12
Romanich
Trying to solve this issue using API
Sub CalculationStart()
Dim Robapp As IRobotApplication
Set Robapp = New RobotApplication
Robapp.Project.CalcEngine.UseStatusWindow = True
Robapp.Project.CalcEngine.AutoGenerateModel = False
Robapp.Project.CalcEngine.AnalysisParams.AutoVerification = I_SAVT_NONE
Robapp.Project.CalcEngine.Calculate
Set Robapp = Nothing
End Sub
 As result information about verification is missing also in robwin.log:
Roman Zhelezniak
Message 7 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
After installing SP3 for Robot 2014 create a new registry:
HKEY_CURRENT_USER\Software\Autodesk\Structural\RSA\27.0\Settings\StructureVerificationOFF with the value 0
Artur Kosakowski
Message 8 of 12
Romanich
Thank you, Artur. Could you look at the reg file?
Roman Zhelezniak
Message 9 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
Artur Kosakowski
Message 10 of 12
Romanich
Thank you, Artur!
For all Robot users - you can find two reg files to quick on/off Automatic Verification in the attachment.
P.S. Don't forget to restart Robot.
Roman Zhelezniak
Message 11 of 12
Romanich,
Nice, but maybe good to post a "user warning" / statement removing any liability from yourself for badly calculated models?
Message 12 of 12
Romanich
Hi Tony,
I think that user must know about the verification itself and such modification that is doing for own risk.
Roman Zhelezniak
