Rotational stiffness
I am still struggling of validating this model (see attached image).
I dont know how to compare the rotational stiffness of the spring to the bending stiffness of the beam. The unit of the spring is kNm/rad and the beam is kNm
This model is modeled in Robot, and the spring is done as a compatible node, with elastic stiffness in place.
Any suggestion would be great.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Artur Kosakowski
Hi, thank you for your reply, can you please explain this for me, as I don’t crealy understand, and if you could send me the model please.
thank you
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
For small rotations you can assume that the beam deflection (u in meters) is the same as angle of rotation at the support (alpha). Having a beam of L length (in meters) with force F [kN] at its middle:
alpha = u / 0.5*L = 0.00135 / 3 = 0.00045
You need to determine the spring value for which the force applied at the end of the cantilever rotate a cantilever of L/2 length by the alpha angle
F * 0.5L / alpha = spring value [kNm/rad]  1 * 3 / 0.00045 = 6666,667
Artur Kosakowski
