ROBOT VS ETABS why have the DIFFRENCE
Message 1 of 50
I set up two models which are etabs and robot. When set both model suport are pinned. the reaction of support is very small different around about 0.01
But when i set support is fixed , the models reaction have a big difference.
why have the  DIFFRENCE ? how can handle it
please help me
Accepted solutions (3)
Replies (49)
Message 41 of 50
saclovitzky
From my previous attachment,if you tick"add restraints on edge if corners have restraints", then the intermediate supports at the bottom points will be considered (it is not graphically displayed), you can check this, just by looking at the deflection of the wall and its joint reactions.
Message 42 of 50
I mean etabs or robot can set one to same support performance
because my project need to verify i know how correctly using robot through the etabs to do that.
i set the model is 31 storey so i use the first to compare the result to verity the correctly using robot
can see my model and give some comment to me ?
https://drive.google.com/drive/folders/1EQIoms-iihILn3x8TNH4U7s_S2y6tUgs?usp=sharing
Message 43 of 50
saclovitzky
your support is not the same, you have linear pinned support in ARSAP and fixed linear support in ETABS
Message 44 of 50
saclovitzky
@Anonymous pls. see attached on example wall calcs,again, the difference of result is negligible.
Message 45 of 50
How can you do that i saw your previously post i try to do that but i cannot saw the result like you . The wall just show default in the wall
Message 46 of 50
saclovitzky
@Anonymous study this,https://www.csiamerica.com/products/etabs/watch-and-learn
I think you have all sufficient evidence that, if you have the same model and run it to any softwares the result will almost likely the same.
Its time for you to decide now, are you using ARSAP or ETABS or what?
If you decide using ARSAP stick to this forum and talk anything but ARSAP, but if you want another software go to their respective site or forum.
In this regard, and in fairness to you, this thread comes to a conclusion now.
Message 47 of 50
Do you set up the wall  model in etabs , is separate the wall to set ?
and the support in wall of robot is equal distance ?
how can i see the distance of wall support in robot?
Message 48 of 50
saclovitzky
see attached
Message 49 of 50
How can i find the picture 2 command which to see separate of the wall  ?
Message 50 of 50
 ok i find it in analysis
