I'm trying to make screencaptures of finite elements structure.
For the moment, i have three questions:
- Is it possible through API to get "extremums" bending moments like on the document enclosed (my problem is that on a simple map, there is no the maximum or minimum value)
- If not, i found an alternative solution that consists in asking for linear supports results on the plate
- The last question is in relation with isolines. I've managed to get isolines. Now, i'd like to control thickness of the lines, number of isolines, and isolines values.
All of these interrogations are detailed in the enclosed PDF.
Thanks for answering,
Regards.
Dear Rafal,
Do you think it will be possible one day?
I thought that all functions were implemented.
VE
