Robot Structural Analysis Professional 2026 HotFix 1
Romanich
Mentor Mentor
Romanich
Robot Structural Analysis Professional 2026 HotFix 1 is available for download!
As a result of detailed information from customers, the following were identified and fixed:
Analysis
Corrected design spectrum definition for seismic analysis according to Portuguese NP EN 1998-1:2010/A1 2013 design code.
Corrected calculations of Time History analysis for a model with elastic supports concerning Hilber-Hughes-Taylor and Newmark-acceleration methods.
Corrected zero base shear value for Spectral Analysis Seismic load cases when automatic base shear calculated with disregard density and load to mass conversion was set for specific modal analysis case.
General issues
Corrected program instability when printout composition containing tables was exported to MS Word document.
Corrected translations of descriptions in the steel design and seismic analysis dialogues.
Steel design
Increased to 180 yield limit for the web of doubly symmetric I-section in bending for NZ_3404 specification.
Corrected wrong reduction for steel capacity depending on section thickness for Japanese AIJ-05 steel design code.
Improved verification for deflections of variable actions in SLS combination.
Timber design
Corrected load duration factor CD for load combinations with response spectrum seismic case according to Tab.2.3.2 of ANSI/AWC NDS-2012 ASD code.
However, since installing the hotfix, this window has appeared when I create a new project:
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
WALIDGIO
they didn't update the What's new for the hotfix in the help section ?
Konrad.O
Autodesk Support
Autodesk Support
@Romanich
Thank you for highlighting the HF1 here! I contacted you regarding the warning you mentioned.
@WALIDGIO, for Hotfixes, release notes are available in Autodesk Account (Roman mentioned them in his post).
Konrad Ociepka
Senior Product Owner - Structural Analysis
WALIDGIO
Thank you @Konrad.O.
I was actually looking for the release notes in the Help section, similar to how it's done for Revit updates.
It might be a good idea to include Hotfix details there as well, so users can easily track changes and updates in one central place.
Konrad.O
Autodesk Support
Autodesk Support
The solution to the warning that showed up for Roman was to clear (recreate, keeping the backup copy) the CfgUsr folder. Here are the steps:
  1. Go to C:\Users\<username>\AppData\Roaming\Autodesk\Robot Structural Analysis Professional 2026
  2. Rename the CfgUsr folder to CfgUsr1.
  3. Restart Autodesk Robot Structural Analysis Professional.
Konrad Ociepka
