robot structural analysis Frame 2D
I have 2 questions and i would be so grateful for an answer.
I tried to design a reinforced concrete Frame,i put the loads and i do the combinations. so i go to ( required reinforcement of RC beams/column ) to check the reinforcement for beams and column and i don't know why the program choose the SLS moment not the ULS to calculate the reinforcement !
the first question is how can i fix it ?
the second question : how can i calculate the reinforcement of the beam in ( provided reinforcement of RC element) with taking in consideration the negatives moments on edges? or put a fixed support on edges not a pinned support.
thank you.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
I'm not sure if I understand the situation correctly. Could you attach some pictures which illustrate your question so that I'm sure I'm looking at the right place please?
Artur Kosakowski
Dear Mr Kosakowski,
kindly find attached a picture showing my problem.
sincerely.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
It seems that you missed the picture.
Artur Kosakowski
Hi Mr Kosakowski,
Sorry ,Here is the picture.
sincerely
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Thank you. Now it's a bit easier to try to help Smiley Wink
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Thank you Mr  Kosakowski,
