Robot Structural Analysis 2026 is live!
Konrad.O
Autodesk Support Autodesk Support
Konrad.O
Autodesk Support
Autodesk Support
Dear Community,
We would like to inform you that Robot Structural Analysis 2026 is live.
New implementations have been described in the What's New document.
Enhancements and issue corrections have been listed in the Release Note document.
It is thanks to you and your commitment that we continue the development!
Please install RSA 2026 - any feedback is valuable to us.
You can follow our plans and work through the analysis-related tabs in Revit - Structure Roadmap.
Have a fruitful design!
RSA Team
Konrad Ociepka
Senior Product Owner - Structural Analysis
umut.akparlar
Thanks @Konrad.O
There have been notable improvements on the steel design side. However, the lack of an RC wall design module for EC2 remains a significant limitation. Currently, RSA does not support RC wall design per EC2, as the provided reinforcement module has not been updated for over a decade.
Best regards,
WALIDGIO
Thanks @Konrad.O
when the seismic analysis for new Algerian code 2024 will be implemented in the RPA, I hope it will be in the hotfix soon.
If the dev team need help on this it will be my pleasure to help
Regards
Konrad.O
Autodesk Support
Autodesk Support
Thank you, @umut.akparlar and @WALIDGIO for your suggestions.
Please see on the public roadmap how the focus is potentially distributed over time.
Konrad Ociepka
umut.akparlar
Thank you, @Konrad.O
I regularly check the roadmap, but unfortunately, there’s still no indication that EC2 RC wall detailing/design will be added to RSA or Revit. This means I have to use additional software like Tekla Structural Designer or ETABS for RC wall design and detailing, which is not ideal, especially since RSA is technically capable of supporting this functionality.
The NF EN 1992 RC wall design was implemented, which is just a variation of the base Eurocode. It’s unclear why the standard EC2 RC wall design wasn’t included, as it could likely be integrated with minimal adjustments. Using multiple tools unnecessarily increases workflow complexity.
Regards.
Eduardo_Meruvia
Hi @Konrad.O ,
Is there plans for Autodesk/Development team to release a 'Road Map' specifically for Robot? Similar to the one done for Revit / Revit Structures.
Appreciate the response.
Cheers
Ed
Konrad.O
Autodesk Support
Autodesk Support
Hi @Eduardo_Meruvia,
Thanks for your question!
For the structures, we keep roadmaps in a common place - Revit structure roadmap. The tabs related to analysis and design refer to the overall Structural Analysis strategy with relevant technologies from our portfolio and ecosystems supporting it.
We want to gather them in one place so you can see the bigger picture of the development.
Konrad
Konrad Ociepka
