When I model a steel structure in Robot I make sure that the member lines in Robot coincide with the centroidal axis of the physical steel members.
When this model is exported from Robot to Revit, Revit treats horizontal and vertical members different.
Vertical members (columns): The lines from the robot file, coincide with the centroidal axis of the revit column (Ok).
Horizontal members (beams): The lines from the robot file, coincide with the top of the Revit Beams (Problem).
Is there any way to change this behavior, so that the horizontal lines from the robot file coincide with the axis of the beams in the Revit File?
Regards
Regards
