Robot parametric run with Dynamo
HenkaCarlsson
Message 1 of 1
HenkaCarlsson
Hello!
I have studied the "Armadillo Spatial Truss - 03 Parametric Run" from the webinar by Dieter Vermeulen.
Autodesk University Dynamo+Robot+Revit workflow Webinar - YouTube
I tried to make it work with Robot 2022 and the latest version of Dynamo + the Strucural analysis pa...
The different Robot models is created and it seems as the calculation is done because I can see that the results become "available". But the saved file is without the result.
If I open one of the models and run the analysis in Robot it works fine.
Any ideas what could be wrong? Why the saved file is without result. Probably that is why the result in the excel-file is missing to.
Best regards
Henrik C
Replies (0)
