Robot doesn't work with mark in Revit model.
toantrungthach01
toantrungthach01
Hi every one!
I'm using the Revit 2022 link to Robot 2022, when I set mark for frame or other element in Revit 2022 and link to Robot 2022, it will be show the "name" in property tab in Robot like "mark" in Revit 2022.
But now, I'm using the Revit 2023. After create model and set mark in Revit 2023, I create the Analyticals and link to Robot. This time, I have a trouble. The "name" in robot doesn't set like Robot 2022, it only create standard like I don't set "mark" in Revit. I would like to link model from Revit to Robot and set "name" in property tab like version 2022 after set "mark".
If you have another way to link mark in Revit 2023 to Robot 2023, please help!
Thank you so much!
MC-ERRL
Observer
Observer
Hi
Is there any update on this issue?
tomasz.wojdyla
@MC-ERRL
We are working on this on different sides. Mind please, that nowadays with updated workflow of handling analytical model in RVT in separation of physical (with or without association) we exchange the data in RSA with properties of analytical model objects. 'Mark' however is mostly covered still for physical (not visible yet for users in properties pallet  for analytical). Thanks
