Robot crashes during calculation
Capture.PNGHi,
I seem to be having an issue with consolidating my mesh, as attached below. Every time I attempt to verify the calculation model robot seems to crash. Do you have any idea what seems to be causing this issue? I have checked the mesh defined separately and I cannot seem to find any issues with it.
Analysis Model
Many Thanks.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Check if this meshed model works for you.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Hi Artur,
Yes this seems to be working now - thankyou very much. How did you get it to work?
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
I assigned 0.1 m Delaunay mesh with the regular meshing switched off to all panels and switched off use of the kinematic constrains. Then I generated the model and froze all meshes.
Artur Kosakowski
