Robot Corus CHS Sections
I'm currently designing a structure in the UK that is mostly comprised of CHS sections and I'm in the process of optimising and rationalising the steelwork results.
However, I've noticed that there are some discrepancies between section sizes that are used in the Corus and the ones quoted within the Tata Steel Blue Book - an example being a 406.4x20CHS is in the Corus database but is not available from Tata (sizes only go up to 16mm dia from Tata), and conversely the Corus database does not include sections marked in the Blue Book as '# - check availability' as well as common sections such as 88.9x8CHS or the 114.3x8CHS. It's important that the sections I use are actually listed in the Blue Book (limited availability aside).
I have looked for the Tata steel sections xml file to load into Robot but to no avail - has anyone had a similar issue? Or is the only option to copy the Corus xml file and remove the sections that are not available and add in the sections that I need?
Many thanks in advance
