Robot Component Manager (API)
jmmarin
jmmarin
Hi all.
I would like to know how to call and manipulate objects created in a model. In particular, I would like to create a footing (for instance) and call to this object using Excel VBA in order to change the properties etc...
I know the code for calling to Robot elements (nodes, bars, loads, etc...) but I have never used the RC component manager (footings, columns, beams, etc...).  Should I load any additional reference in Excel?
Dim robApp As RobotApplication
Set robApp = New RobotApplication
Dim robCim As RobotProjectComponentMngr
Set robCim = robApp.Project.ComponentMngr
Thanks in advance.
Accepted solutions (3)
Stephane.kapetanovic
hi @jmmarin
(API) MACRO FOR FOUNDATIONS
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
jmmarin
Thanks for the reply!
Do I need to load reference "Robot Concrete Footings" or just RobotOM?.
Regards!
hi @jmmarin
First run the example code with RobotOM.
jmmarin
Yes, it works. I have access to the object.
