Robot Command Line
Robot Command Line
Dias_Antonio
Robot Command Line
Dias_Antonio
Hi everyone
Is there a way to input commands in Robot (type in a command line) like AutoCAD or Autodesk Advance Steel?
- Marque "Aceitar como Solução", caso tenha resolvido seu problema.
- Select "Accept as Solution", if it has soplved the problem.
- Clique em "Curtir" se a resposta ajudou.
- Click on "like" if the answer helped.
Antonio Dias
|Linkedin|Instagram|Facebook|Twitter|YouTube|
Colaborador da Comunidade de Usuários Autodesk Brasil
Romanich
Not possible, but you may find an obsolete command line in the Load table:
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Dias_Antonio
Thank you Romanich.
Antonio Dias
