Robot API
Robot API
Max-88
Message 1 of 8
Robot API
Max-88
I have looked at one of Rafal's old posts showing how to create a dll and make it available in Robot, tried same in Visual Studio 2016 Community Edition and I could not figure out how to add the created *.tlb library to *.dll file, point 9 in the attached doc.
Copyright note: the attached doc belongs to and has been posted previously by Rafal šŸ™‚
I have searched the web, no luck.
Needless to say that my programming skills are not up to scratch.
Can anyone enlighten me on this?
cheers
max
Replies (7)
Message 2 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
According to google there is no VS 2016 \ VS 2016 CE
https://www.google.ch/search?q=visual+studio+2016&ie=utf-8&oe=utf-8&gws_rd=cr,ssl&ei=CMQ4VtPfDpCejwP...
but of course I can be mistaken
Rafal Gaweda
Message 3 of 8
Max-88
Hi Rafal,
My bad, it was Microsoft Visual Studio 2015 Community Edition I was referring to.
https://www.visualstudio.com/products/visual-studio-community-vs
Thanks for looking into this.
cheers
max
Message 4 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
It seems this version of VS does not contain Resource Editor.
We will see what we can do.
Rafal Gaweda
Message 5 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
I am afraid there is no other solution than buying full VS to edit dll in the way it is required.
Or create exe instead of dll.
Rafal Gaweda
Message 6 of 8
m_redmerski
Hello Rafal,
Is there any chance to use free tools to build a dll robotaddin? VS Enterprise license is quite expensive for single designer.
Regards
Message 7 of 8
m_redmerski
maybe this tool can help: http://www.resedit.net/
the problem is that when i attach the tlb using this tool. And then try to register it to .net I have an error that it's not a .NET assembly
Message 8 of 8
i guess you should check interop***.dlls in robot "exe" directory.
there are 3 such kind dlls. you can reference one with "robot" in it's name.
