Robot API - Setting Analysis Parameters
milczarekuba
milczarekuba
How could I set some Paraameters of Buckling Analysis through Robot API. I've created new buckling analysis:
app = RobotApplicationClass()
NewBucklingCase = app.Project.Structure.Cases.CreateSimple(cases_new_number,BucklingCaseName,IRobotCaseNature.I_CN_EXPLOATATION,IRobotCaseAnalizeType.I_CAT_STATIC_BUCKLING)
then I'd like to change  number of modes
@Rafal.Gaweda i saw that you are into  Robot API, can i have some help from you?
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @milczarekuba
Example code
    Dim Simplecase As RobotSimpleCase
    Dim CaseServer As RobotCaseServer
    Dim BucklingParams As RobotBucklingAnalysisParams
    Set CaseServer = robapp.Project.Structure.Cases
    Set Simplecase = CaseServer.CreateSimple(1, "Buckling", I_CN_EXPLOATATION, I_CAT_STATIC_BUCKLING)
    Set BucklingParams = Simplecase.GetAnalysisParams
    BucklingParams.ModesCount = 50
    Simplecase.SetAnalysisParams BucklingParams
Rafal Gaweda
milczarekuba
@Rafal.Gaweda
Thanks a lot.
In Python it works as well.
