Robot API - set display flags of current view
LionelDallenne
LionelDallenne
is it possible to set the display flags "Section - shape" and "Sections - legend by colors" (see screenshots below) of the current view automatically to true using APIs?
Many thanks,
LionelDallenne
And related to the same topic, would it be possible to, again through APIs, highlight both load values and symbols for  a selected load case (10 in this example)
Thanks again
Stephane.kapetanovic
hi @LionelDallenne
Public ViewMngr As IRobotViewMngr
Sub Show_SectionsColor_LoadsCase10_on_ActiveView()
  Dim Robapp As IRobotApplication: Set Robapp = New RobotApplication
  If Robapp.Visible <> -1 Then ' Open Robot and a project
    Set Robapp = Nothing: Exit Sub
  Set ViewMngr = Robapp.Project.ViewMngr
  Dim ActiveView As RobotView: Set ActiveView = ViewMngr.GetView(ActiveViewNumber)
  'Possible to Limit/Add display attributes in the list below
  DisplayAttributes = Array(I_VDA_LOADS_VALUES, I_VDA_LOADS_SYMBOLS_CONCENTRATED, I_VDA_LOADS_SYMBOLS_LINEAR, _
                            I_VDA_SECTIONS_COLORS, I_VDA_SECTIONS_SHAPE)
  Dim ParamsDisplay As RobotViewDisplayParams: Set ParamsDisplay = ActiveView.ParamsDisplay
  For Each attr In DisplayAttributes: ParamsDisplay.Set attr, True: Next
  ActiveView.Selection.Get(IRobotObjectType.I_OT_CASE).FromText "10"
End Sub
Function ActiveViewNumber()
   For i = 1 To ViewMngr.ViewCount
     If ViewMngr.GetView(i).Window.IsActive <> 0 Then
       ActiveViewNumber = i: Exit Function
   Next i
   ActiveViewNumber = 1
End Function
Best regards
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
LionelDallenne
Thanks @Stephane.kapetanovic ,
I'll have a closer look at it in the next days. Thanks already.
