ROBOT API - problems of existants connections
durducgeorge
durducgeorge
I want to modify somme lengts or widths of some existent. And when I have a connection like this:
durducgeorge_0-1752477574567.pngand the plate on bottom is deleteddurducgeorge_1-1752477655996.png.
My code is:
List<int> totalAss = new List<int>();
RobotApplication RobApp = new RobotApplication();
RobotStructure RPS = RobApp.Project.Structure;
IRJointConnectionServer JointServer = RobApp.Project.Connections;
int num = 0;
int numbers_of_ass = 0;
numbers_of_ass = JointServer.Count;
for (int i = 1; i <= numbers_of_ass; i++)
num = i;
IRJointConnection Connection = JointServer.Get(num);
RJointConnectionInfo Info = JointServer.GetInfo(num);
Info.DefType = IRJointConnectionDefType.I_JCDT_IN_STRUCTURE;
double hauteur_profile;
if (Info.Type == IRJointConnectionType.I_JCT_KNEE_BOLTED && Info.Name == "Angle de portique")
IRJointKnee jointKnee = (IRJointKnee)Connection;
string jarretCommun = "";
double angleBeam = jointKnee.Beam.Angle;
// determinaation jarret du noeud commun
RobotBar beam = (RobotBar)RPS.Bars.Get(jointKnee.Beam.BarNumber);
int noNodeCommun = 0;
int coeffIfAngleObtuz = Utilities.isObtuzAngle(
ref RobApp,
jointKnee.Beam.BarNumber,
jointKnee.Column.BarNumber);
if (beam.EndNode == ((RobotBar)RPS.Bars.Get(jointKnee.Column.BarNumber)).EndNode)
noNodeCommun = beam.EndNode;
else if (beam.EndNode == ((RobotBar)RPS.Bars.Get(jointKnee.Column.BarNumber)).StartNode)
else if (beam.StartNode == ((RobotBar)RPS.Bars.Get(jointKnee.Column.BarNumber)).EndNode)
noNodeCommun = beam.StartNode;
else if (beam.StartNode == ((RobotBar)RPS.Bars.Get(jointKnee.Column.BarNumber)).StartNode)
if (beam.EndNode == noNodeCommun)
//MessageBox.Show(beam.Start.GetLabel(IRobotLabelType.I_LT_BAREND_BRACKET).Name);
try
jarretCommun = beam.End.GetLabel(IRobotLabelType.I_LT_BAREND_BRACKET).Name;
catch (Exception e)
Console.WriteLine(e);
throw;
if (beam.StartNode == noNodeCommun)
jarretCommun = beam.Start.GetLabel(IRobotLabelType.I_LT_BAREND_BRACKET).Name;
double hauteurPerpJarret = Convert.ToDouble(jarretCommun.Split('x')[1].Split(' ')[1]) -
2 * jointKnee.BracketLow.ThickFlange;
double longueurHarret = jointKnee.BracketLow.Length;
double angleJarret = Math.Asin(hauteurPerpJarret / longueurHarret);
double angleDeDetermionat =
angleJarret + Math.Sqrt(angleBeam * angleBeam) * Math.PI / 180 * coeffIfAngleObtuz;
jointKnee.StiffTypeLow = IRJointKneeReinfType.I_JKRT_BRACKET;
jointKnee.BracketLow.Height = (hauteurPerpJarret + jointKnee.BracketLow.ThickFlange) /
Math.Cos(angleDeDetermionat);
jointKnee.Bolts.ShearPortion = IRJointBoltShearPortion.I_JBSP_THREADED;
if (Convert.ToDouble(jointKnee.Column.Section.Split(' ')[1]) < 450)
jointKnee.WebColumnStiffenerHUpper.Thick = 10;
jointKnee.WebColumnStiffenerHLower.Thick = 10;
else
jointKnee.WebColumnStiffenerHUpper.Thick = 15;
jointKnee.WebColumnStiffenerHLower.Thick = 15;
Connection.SetToRobot(Info);
Best regards,
George DURDUC
Stephane.kapetanovic
hi @durducgeorge
have you tried
jointKnee.KneeType = IRJointKneeType.I_JKT_BEAM2COLUMN_CONTINUE;
Best Regards
Stéphane Kapetanovic
don't forget to click the Accept Solution button and leave a < like !
durducgeorge
hi @Stephane.kapetanovic ,
it doesn't work. it makes column continue, but it's not good for my case.
The problem in fact is that before I "SetToRobot" when debugging, the jointKnee has the good length, thick and width but it shows that it doesn't exist (0 value for Exist...).
And even if I force with the value 1 it doesn't word (look below):
did you add
jointKnee.StiffTypeUp = IRJointKneeReinfType.I_JKRT_STIFF;
durducgeorge
yes, I add it. It doesn't work (it doesn't activate the stiffner type of bracket). But when I type this for the StiffTypeLow it works everytime ( only for the up side doesn't work).
durducgeorge
Now It works only if I presse the apply button on the connection in Robot.
However, it would be nice if I can activate from Robot the presence of stiffener or bracket.
Well, it's ok even with that.
Thank you for the help Mr. @Stephane.kapetanovic !
Best regards!
to remove the upper stiffener
jointKnee.KneeType = IRJointKneeType.I_JKT_BEAM2COLUMN;
jointKnee.StiffTypeUp = IRJointKneeReinfType.I_JKRT_NONE;
IRJointKneeBracket BracketUp = jointKnee.BracketUp; BracketUp.Exist = 0;
BracketUp.Width = 0; BracketUp.Length = 0; BracketUp.ThickFlange = 0; BracketUp.ThickWeb = 0;
to add it
IRJointKneeBracket BracketUp = jointKnee.BracketUp; BracketUp.Exist = 1;
BracketUp.Width = 80; BracketUp.Length = 160; BracketUp.ThickFlange = 0; BracketUp.ThickWeb = 10;
