Robot Analysis Warnings (cladding load distribution) (Instability 1,2 and 3)
Some descriptions about the attached model, from which may someone get what caused such warnings:
> Regarding the "the load has not distributed correctly, there are no objects or elements carrying the load overlap"
- The cladding defined as "one way-x" to distribute the load as desired. (with edge bars)
- I did define the cladding at first, then assigned to it some area load, then wind simulation was been performed.
Also, is it mandatory to define cladding before performing wind simulation, or could I did that without any claddings ?
> Regarding the "Instability 1,2 and 3" warnings:
- In the modelling, I did define some bars as "truss", and all the rest as "beam" with Ry Rz releases.
- All supports are pinned.
Also, is it a problem if one joint has more than one member with the same releases at its end which at this joint?
Thanks in advance,
Emad
