Robot 2018 high resolution problems
marko.glavinic89
Message 1 of 18
marko.glavinic89
I have installed Robot 2018 and I have few problems while running it on high screen resolution (3840x2160). It is very slow in model view, rotating, zooming, results.... I tried turning Hardware acceleration off and it did help a bit, but still very slow.
In addition, I can't select or change display settings, as shown on the image.
I haven't used old versions on this screen resolution so I can't say if this is only 2018 problem or it happened in older versions also.
Thank you.
Replies (17)
Message 2 of 18
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @marko.glavinic89
I'm sorry but Robot interface is not customized for UHD screens Smiley Sad
Artur Kosakowski
Message 3 of 18
marko.glavinic89
So it means I have to lower my screen resolution every time I work in Robot?
I wouldn't mind it's so slow, but is there any way to properly see all the display options?
For example, I can't select panel thickness or mark by colours...
Message 4 of 18
Artur.Kosakowski
Autodesk Support
Autodesk Support
Try to make this settings
Artur Kosakowski
Message 5 of 18
marko.glavinic89
Tried it, still no effect. Can't select or change anything in Display settings.
Another thing I noticed, when I set Display acceleration to full in preferences, 3D view runs smoothly, but when I try isolating object in "Edit in new window" I becomes so slow it's merely impossible to work.
Just to mention, model is a simple 3 story building, total size 1.200kB, with no mesh generated, running from a SSD on an i7 with 16GB memory...
Message 6 of 18
Artur.Kosakowski
Autodesk Support
Autodesk Support
You may try to check for the latest graphic card driver and delete Windows temporary files (%temp% folder).
Artur Kosakowski
Message 7 of 18
marko.glavinic89
Driver version is from 1 May 2017.
I tried deleting temp folder with no effect.
Message 8 of 18
marko.glavinic89
* UPDATE *
I did, however, install older version of graphic card drivers and so far it works smooth, both in default 3d view and isolated views.
Still can't see display settings, nor can modify them.
Message 9 of 18
Artur.Kosakowski
Autodesk Support
Autodesk Support
Try to make the column wider dragging the indicated line sideways
Artur Kosakowski
Message 10 of 18
marko.glavinic89
Oh, it worked, so simple ! 😄
After yesterdays smooth run today I get the same problems again, slowing down when isolating objects in separate views...
Message 11 of 18
Artur.Kosakowski
Autodesk Support
Autodesk Support
Could you check if by any chance the driver updated automatically in the background?
Is it a laptop or a desktop?
Does it have one or two graphic cards and what exactly they are? What are its (their )driver(s)?
Is it possible that for a laptop is starts to work in some safe energy mode?
Artur Kosakowski
Message 12 of 18
marko.glavinic89
It's a desktop computer, Lenovo Rethink P310, with one graphic card, Nvidia Quadro K620, drivers dated on 01.08.2016. (checked as I type)
Message 13 of 18
Artur.Kosakowski
Autodesk Support
Autodesk Support
Could you check if installing this driver helps?
http://www.nvidia.com/download/driverResults.aspx/123229/en-us
Artur Kosakowski
Message 14 of 18
marko.glavinic89
Installed it, didn't help, still the same...
Message 15 of 18
marko.glavinic89
After consulting with our technical support for Robot we came to the solution. At least for now..
In nVidia Control Panel, under Manage 3D Settings/Program Settings add Robot and customize settings. My current settings on which Robot runs smoothly are shown on the image below.
Message 16 of 18
Artur.Kosakowski
Autodesk Support
Autodesk Support
Thank you for sharing this information.
Artur Kosakowski
Message 17 of 18
i have the same problem ( small icons )
but my graphics are different !
anyone use this graphics and solved the issue ?
Smiley Sad
Message 18 of 18
okapawal
The issuses with scaling on high resolution moniter has been corrected in Robot Structural Analysis 2020.1 Update
Waldemar Okapa
Sr Product Owner
