Good day everyone!
I have a question I hope you could answer. I'm working on a steel model in Robot with a compound section, as shown below. I want to export this model into Revit to calculate quantities and generate blueprints for construction and fabrication, but every time I try to export a model with a compound section into Revit, the latter crashes because of the section. I know the compound section is the problem because I tried exporting the model without those sections and it works just fine.
Is there any way to create a compound section in Revit? Or is there any way to generate the construction and fabrication blueprints in Robot?
Thank you so much for your time and for your answer!
