Revit to Robot elevations exported as positive and elements as negative
Message 1 of 10
I exported a model from Revit to Robot and am having an issue with the elevations. In the exported RSA model, the elevations are in the correct position in the Z-axis; however, the elements are not aligned to the elevation and they are positioned in the negative value of what the correct elevation is. Has anyone else run into this issue when exporting Revit to Robot?
Thank you in advance!
Replies (9)
Message 2 of 10
Rafacascudo
Not sure of what you meant by "the negative value of what the correct elevation is".
Can you provide some pics explaining what you mean?
Rafael Medeiros
Message 3 of 10
Thank you for looking into this issue. I have attached a few photos to illustrate the problem that I am experiencing. Hopefully they help to clarify.
Message 4 of 10
Rafacascudo
Never went into this kind of problem.
While you wait for official support , you could try to move the whole model into its correct position and see what happens when you export it back to Revit , if you need to.
Rafael Medeiros
Message 5 of 10
Thank you for the suggestion. I considered moving the elements in the model; however, I have several models that have the same problem. Each of the models have several elements and I would like to save some time by exporting them to the correct elevation rather than adjusting each model.
Message 6 of 10
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
Could you please be so kind and send us Revit file?
Rafal Gaweda
Message 7 of 10
Thank you for looking into this. @Rafal.Gaweda, Could I send the file to you directly? I cannot post the file on the forum.
Message 8 of 10
UPDATE: I believe that this has something to do with the difference in basing the elevations off of the Project Base Point and Survey Point in Revit. The levels in the Revit model are based on the survey point which is N/S: 0, E/W: 0 and Elevation 0. Our Project Base Point (which is where the top of the first level is) is N/S: 235821'  2 83/128", E/W: 2272124'  8 87/128", and Elev: 847'. Would it be possible to move either the base point or the survey point so that when I link the model to Robot, the levels and building are in the correct Z-coordinate? Could someone please explain how Robot interprets the Survey Point and Base Point? My understanding is that the grids for the levels are linked in Robot to the elevation from the Survey Point, which is why the levels are roughly around the Z-coordinate of 847'. Then, somehow the project (or building) off-sets itself in the negative z-direction from the Survey Point. Can someone please explain this to me?
Message 9 of 10
Here are a few photos to illustrate the locations of each point.
Message 10 of 10
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
Please send me the link to file by Private Message on forum
You can send the file  \ generate link to file this way.
Rafal Gaweda
