Revit export to robot
Bafranstudio
Bafranstudio
Why doesn't the design image result appear in the robot software when exporting Revit to Robot Structural? Please help me
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @Bafranstudio
You probably have not created analytical model in Revit.
Follow the steps.
Follow the steps.
  1. Open Revit 2024 and Robot Structural Analysis 2024.
  2. Create physical model in Revit.
  1. Create analytical model in Revit using Analyze >Analytical Automation >Physical to Analytical option
  1. Select objects in Revit and press Run.
  1. Export analytical model to Robot with Analyze >Robot Structural Analysis >Robot Structural Analysis link> Send model
Krzysztof Wasik
teixeiranh
Hello
If you want help with your problem you need to explain yourself a bit more. What have you done? What were the steps?
Only then you will get proper help.
“The most powerful force on the universe is compound interest.”
Subscribe me on Youtube:
https://www.youtube.com/channel/UC6G8OOp318Z1MFzJj5T8uWw
