Results connect to excel
dimogrec
Message 1 of 23
dimogrec
Hi
is Reults Connect compatible with MS excel 2007 32Bit ?
Which versions of excel are compatibile with Autodesk Results Connect 2016?
Thanks in advance
Replies (22)
Message 2 of 23
Rafal.Gaweda
Autodesk Support
Autodesk Support
all MS Excels starting from 2007 ; 32 and 64 bit
Rafal Gaweda
Message 3 of 23
Dear Support,
I downloaded and installled RSA 2016 with SP1 on windows 7 x64 bits.
I Have excel 2007 32 bits but the result connects ribbon does not exist !
What should I do?
Your support is appreciated .
Thank you
Wassim
Message 4 of 23
Rafal.Gaweda
Autodesk Support
Autodesk Support
Reinstall Results Connect and check:
http://we.tl/GEMN9caqDv
Rafal Gaweda
Message 5 of 23
Thank you Rafal, It Works.
Wassim
Message 6 of 23
Hello Rafal, the Result Connect installation file is not available in the llocation to the link provided. Could you make the file available once again.
Message 7 of 23
Rafal.Gaweda
Autodesk Support
Autodesk Support
New link : http://we.tl/Vo0fFB4i97
Rafal Gaweda
Message 8 of 23
w.adam.bim
hi .. the link expired .. so could you upload again...
Message 9 of 23
Rafal.Gaweda
Autodesk Support
Autodesk Support
Attached
Rafal Gaweda
Message 10 of 23
w.adam.bim
thanks alot
Message 11 of 23
Hello Rafal,
Could you please upload Result COnnect 2016 once again as the link has expired ?
Thanks in advance.
Message 12 of 23
Rafal.Gaweda
Autodesk Support
Autodesk Support
Message 13 of 23
stosto6666
I still have problems with Results connect running on my Excel (x32 v.2010).... Please see the screen captures attached. Thanks
Message 14 of 23
stosto6666
I can't see the file which I needed in the Excel add-ins, please see next picture...Please help!!!
Message 15 of 23
I have the same problem:
Bump!
Please help me make RSA 2016 great again! Smiley Sad Man Sad Woman Sad Robot Sad
Message 16 of 23
stosto6666
I have no solution yet!
Message 17 of 23
Rafal.Gaweda
Autodesk Support
Autodesk Support
Delete everything from:
c:\Users\%USERNAME%\AppData\Roaming\Autodesk\Results Connect\2016\
replaces files in
c:\Program Files\Autodesk\Results Connect\2016\Framework\Configuration\
by the ones from attached zip
Rafal Gaweda
Message 18 of 23
stosto6666
Thanks Rafal, Your solution solved the problem!
Message 19 of 23
Thanks!
May the ELDER Gods Be with you!
Message 20 of 23
Hi Rafal,
Having a similar problem - can't find Results Connect files for RSA 2017.. is there any place I can download this?
Mishlin
