Hi!
I am using Robot Structural Analysis Professfional 2014 and I would like to start using Results Connect.
How to I download it and it it compatible with Robot Structural Analysis Professsional 2014 and Excel 2016?
Thanks.
Solved by Muhammed.OPERA. Go to Solution.
Hi @cool.stuff
Results connect is downloaded with the program since it was implemented with Robot 2016.
See additional requirements > system requirements here: https://knowledge.autodesk.com/support/robot-structural-analysis-products/learn-explore/caas/CloudHe...
It work with all versions of Excel since 2007.
Muhammed Mamdouh (OPERA)
Structural Engineer, Instructor
Facebook |LinkedIn
Thank you for your answer and help.
But it does not tell if it is compatible with Robot Structural Analysis Professional 2014. Also, Results Connect does not come with the instalation files of Robot 2014.
How do you know it is compatible? I could not find anything online.
Thanks.
You can download it here: https://forums.autodesk.com/autodesk/attachments/autodesk/351/38264/1/Autodesk_Results_Connect_2016_...
Facebook |LinkedIn
To be honest with you, i haven't tried to use it with a later version than 2016 but you can download it, then give it a try.
Facebook |LinkedIn
