Result value -1.# IND
Could you please help me on this problem, when I show internal force in my model, I see that they only show the value -1.#R, -1.#J. Could you let me know what is it problem, what am I wrong in my model ? Thank you very much.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
You need to correct the gamma angles for these bars:
Artur Kosakowski
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
I just wanted to check if my suggestion solved the situation you described.
Artur Kosakowski
Thank you very much, your solution work very well.
