Reset view parameters
BertelliMarco1095
BertelliMarco1095
How is possible reset the view paramterers?
I changed the thema some time ago and now I'm not able to get the original parameters.
I'm going crazy! please help me!
Rafal.Gaweda
Autodesk Support
Autodesk Support
delete the file
c:\Users\user_login\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis 2014\CfgUsr\vistemplates.xml
before next robot start
Rafal Gaweda
BertelliMarco1095
Dear Rafal,
Thanks for your fast answer
I moved the file away but the colors do not change. Probably I not explained well the problem: I would like reset to the original the screen colors (nodes colors, rigid plane colors.. etc. etc..)
Romanich
Ciao Marco,
Maybe this option will help you:
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
BertelliMarco1095
he he very easy. Thanks
Hasn't helped me - using 2017 version.
Any further suggestions?
Artur.Kosakowski
Autodesk Support
Autodesk Support
HI @Anonymous
Try to rename c:\Users\user_login\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis 2017\CfgUsr folder
Artur Kosakowski
