Required Reinforcement _Beams
luismrf
luismrf
i have in the required reinforcement because the required area to the top required reinforcement area is 0.91 cm2 and the provided reinforcement is 2f16, (2x2.01 cm2), and in the row above i have 0.93 cm2 of required reinforcement and i get 2f12 (2x 1.13 cm2), this doesn´t make sense, because i chosse to the top and bottom reinforcemnte the f12 only.
Why this happens?
Simau
Hi @luismrf
In Viga parameters, set f8 as longitudinal reinforcement
M. Agayr
MRizea
Hi. Quick question. I tried geting the results that you showed us for "Required member reinforcement", but I have no results. I used the RC module for beams and columns and got results, though I have an empty table for  "Required member reinforcement".
Can you tell me your workflow to get that table populated?
Thank you.
