Remove plot of wind simulation
TorgrimO
TorgrimO
I ran a wind simulation for load case 5 and when I have case 5 selected the pressure is shown. I have since removed the wind loads from this case in the loads table and defined the wind loads "by hand". The contour plot of the pressure on elements is still showing. How can I get rid of the contour plot?
Artur.Kosakowski
Autodesk Support
Autodesk Support
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
marius_jablonskis
Hi Artur, that's rather a quick temporarily fix than a solution. Issue is that every time when switching to display load symbols on and of, it gets back there. Is there a way of permanently ripping away pressure maps from a file?
marius.jablonskis did you manage to get this issue solved?
vaun_bhowani5CT9H
Community Visitor
Community Visitor
Hey. I isolated my map to a Case and deleted the entire case from my load table. Once I added the load back with the same name and case number, the map was no longer there.
