Hello!
1. How can I create a single reinforcement which would be placed not in the axis of a wall, but near the edge ?
2. II would like to create a single almost-vertical reinforcement covered by 4 cm of concrete (from the exterior). What reinforcement direction should be taken? The wall is not perfectly vertical.
Solved by Artur.Kosakowski. Go to Solution.
Robot will always calculate both top/right and bottom/left reinforcement.
Set it as the global Z.
Ok, but there is a possibility to create a single reinforcement in the axis. I was wondering if I could move it to the one of the edges without duplicating it on the other side.
True but for tension/compression only (no bending). Looking at your picture I assumed you actually have bending in what looks like a sort of retaining wall. Am I correct?
Presented wall has such a complicated shape, because it is a chimney's segment. That's exacly what I want prepare for analysis (so there is neither tension/compression nor bending presented). I attach the project.
The problem is that I cannot model single reinforcement that is not placed in the wall centre.
This chimney has only "external" reinforcement hidden 4 cm under the edge. There is no reinforcement closer to the centre.
Such reinforcement arrangement is not supported in Robot but as I wrote if the reinforcement at the other (top) side is not needed its value will be calculated as zero.
Try:
