Reinforcement area
audryszazx
Reinforcement area
audryszazx
I know there is no single answer to this question, but I'll try here... I try to model one slab with 6 different types of mesh. Slab dimensions is 2m x 10 m. With linear supports at the end and one nodal support in the middle of slab. I take 6 types of mesh:
1. 2m;
2. 1m;
3. 0,5m;
4. 0,25m;
5. 0,1m;
6. 0,05m;
Everytime I take smaller mesh size I get bigger reinforcement area in nodal support. I know that smaller mesh size shows better results, but it takes longer to calculate.
My questions is:
1. How do you think, what is the best mesh size? What mesh size do you choose for calculating slabs?
2. If i take mesh 0,25m and reinforce top layers (X direction) with 12 cm^2/m (ø16, 200mm), do I make a big mistake because it requires 21,7 cm^2/m (ø18, 200 mm) with 0,1 m mesh?
I have bigger model with concrete slabs and walls, and if I take 0,2 m mesh, i get very big reinforcement area, but if i take 0,25 m mesh, it looks quite good. So i do not know what mesh size is good enough to continue slab reinforcements. Thanks for helping. I will add RSA 2011 file as example.
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @audryszazx
I would recommend the following.
  • Using advanced support properties defining support  (column) shape
  • Defining mesh size about 1/3 of support size (edge length or diameter)
  • Usinr reducing forces above columns and walls while reinforcement calculation.
Refer to video
Krzysztof Wasik
audryszazx
yes I do that in my main model.
But I still get bigger reinforcement in these red zones, when I use smaller mesh size.
So if my walls width is 250 mm, I should take slab mesh size about 80 mm? Now my mesh is 250 mm
Columns are 400x400.
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @audryszazx
I would use mesh size near walls equal to half of wall width. Over supports I would use mesh size about 150 mm. Concentrations are caused by numerical effect for Finite Element method (singularity in concentrated supports or under concentrated nodal forces) in those regions calculated forces incerases while mesh size reducing.
Krzysztof Wasik
audryszazx
So all slab mesh is 0,15, and at the wall 0,125?
And what about this question:
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @audryszazx
I would suggest
wall /slab connection region about 0.125 m (in slab and wall)
column region 0,150 in slab (but it can be 0.125 as well)
In other slab /walls region (in distance from supports) mesh can have bigger size (0.500).
Krzysztof Wasik
cerveiramatheus
You also can handle this with a non-linear plastic analysis concept.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
