Reinforcement area
- Mute
- Permalink
- Report
I know there is no single answer to this question, but I'll try here... I try to model one slab with 6 different types of mesh. Slab dimensions is 2m x 10 m. With linear supports at the end and one nodal support in the middle of slab. I take 6 types of mesh:
1. 2m;
2. 1m;
3. 0,5m;
4. 0,25m;
5. 0,1m;
6. 0,05m;
Everytime I take smaller mesh size I get bigger reinforcement area in nodal support. I know that smaller mesh size shows better results, but it takes longer to calculate.
My questions is:
1. How do you think, what is the best mesh size? What mesh size do you choose for calculating slabs?
2. If i take mesh 0,25m and reinforce top layers (X direction) with 12 cm^2/m (ø16, 200mm), do I make a big mistake because it requires 21,7 cm^2/m (ø18, 200 mm) with 0,1 m mesh?
I have bigger model with concrete slabs and walls, and if I take 0,2 m mesh, i get very big reinforcement area, but if i take 0,25 m mesh, it looks quite good. So i do not know what mesh size is good enough to continue slab reinforcements. Thanks for helping. I will add RSA 2011 file as example.
