reduced result
reduced result
saclovitzky
reduced result
saclovitzky
Normally,when I go to reduced result for panel.
I can see all forces on the 4 sides of the panel.
At them moment, all I can see are the values for bottom and top of panel(pls. see attached screenshot).
I cannot see the forces on the vertical sides!
Any help will be greatly appreciated
Simau
Hi @saclovitzky
Right clic on the results table and  select "table colums" then clic on "cut" tab.
Select the 2 top boxes
M. Agayr
saclovitzky
Thanks@Simau previously I got used to see all these values automatically:)
