the link below outlines the recommended meshing requirements for a panel. however is this the same for a floor slab panel also or just for a wall panel i.e. same meshing configuration for wall panels except using the delunays option instead of coons when meshing floor slabs? Or do the greyed out areas require changing also when meshing a floor slab? Do you Need too use emitters? Any advice on this or recommendations on this would be most appreciated.
S.
