Hello
I simulated a building in Revit structure 2016. I created some new objects and attached them to the building's elements. Then I created some project parameters for these object. After that I exported the revit file as an IFC file. I opened the IFC file and added some values to the parameters which I created in Revit. Till here everything was Ok. But when I opened the IFC file in Robot structural analysis, I couldn't see the new objects (specialty equipment categories) and their parameters in Robot. Could u please tell me how these data can be appeared in a structural analysis tool for further analysis?
If it cannot be appeared in Robot, is there any structural analysis software which is able to read and show the user-defined ifc property sets and their values?
Thank u so much in advance
Solved by Rafacascudo. Go to Solution.
Robot only reads data related to beams , columms, slabs and walls
Rafael Medeiros
Robot Structural Analysis
Thanks. Do you know whether there is any structural analysis software which is able to do it? I mean which structural analysis tools can read all elements from an IFC file? Thanx
