Re Warning for reinforcement calculations in a cross section
Good day to everyone,
I modeled a concrete building building structure.  The framing type of the building is Dual System; combination of SMRF and shear walls. The analysis phase is successful. However, after the design phase of concrete members, most of the concrete columns have warnings. The warning being issued is "Warning for reinforcement calculations in a cross section" as shown in the attached image.  I can't find such warning in  Errors and Warnings - Modules of RC Element Design.
What is the cause of this warning, anybody?
Solution to this issue will be greatly appreciated.
Thank you.
khimpitou
Please check your column material using bz I saw you use simple bar
Artur.Kosakowski
Autodesk Support
Autodesk Support
Try to run reinforcement calculations of this bar being on the RC Members - required reinforcement layout and add display of Remarks column on the beams, columns and general tabs of the reinforcement table.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Good day Artur,
The warning persists despite adjustments made based on cited suggestions.
Please see attached files.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Could you attach the rtd file so that I have a chance to check this situation?
Artur Kosakowski
Artur.Kosakowski
Autodesk Support
Autodesk Support
In fact the warning is excessive.  It is triggered by incorrect comparison of actual spacing of stirrups with the maximal allowed by the ACI code.
Artur Kosakowski
