RC Design Module - Change steel grade of existing manual reinforcement
Joe_Hughes
Joe_Hughes
How can I change the steel grade of the existing reinforcement I've manually modelled.
- The reinforcement grade was initially set with a fy=410N/mm2.
- I've updated the moving-load load cases therefore I've had to re-run the analysis to send the info to the RC Design Module.
- Then to re-establish the manually inputted reinforcement I had to copy the initial reinforcement to the clipboard, then paste into the RC Design Module once the model was re-analyzed for the updated moving loads. However during the copy & paste process the steel grade of the reinforcement changed from fy=410N/mm2 to B500C. How can I change to 410N/mm2?
Note I initially worked on the file in 2018 using Robot version 2016. However I've updated the moving loads, then copy & pasted the reinforcement into the RC Design Module in 2021 using Robot version 2019.
File is 88MB therefore unable to attached it.
Joe
Joe_Hughes
Problem solved, I've answered my own question again.
Go into Tools > Job Preferences > Reinforcement > Edit the selected database.
Then in the RC Design Module, go to calculation options then select the desired steel grade. Then re-run the calculation within the RC Design Module.
