Message 1 of 21
02:32 AM
Hi;
I have some questions about RC results :
1) How can I change no. of current combination or ponderations from "plates theoretical reinforcement" to see maps of corresponding internal forces, displacements ?
When I am in the option "plates theoretical reinforcement" the current load selection window is inactive.
2) Working with scales is a "nightmare" .
- first of all, it's hard to define your scale
- if you do it you have to read it all the time because the Robot mixes the units
- why Robot does not remember the appropriate defined scales with units, e.g. (reinforcement cm ^ 2 / m, forces kNm / m, kN / m, cracks width mm)
Here are some examples:
Maybe I'm doing something wrong and it's my fault ?
Please tell me how to define user scales and assign them to specific quantities so that Robot reads them well ?
Or maybe something has to be changed in the configuration files (*.cfg etc..) and set it there manually?
