I am attempting to design a RC Core. I am using BAEL the French Code for RC Elements.
I have some problems when trying to design the reinforcement and have found resources to help in this area extermely limited.
1. When I leave the bar diameter options in the "Reinforcement Pattern" menu as "auto" the Robot returns a design using almost always 6mm bars and an extremely dense arrangement of steel. When I change the bars to larger sizes, even as high as 50mm the steel is still very dense. Why is there not a noticable change?
2. I have the calcualtion error "The opening 'H1' coincides with edge reinforcement!" I was wondering what I can do to fix this? I have tried everything exept changing the core wall thickness. I have also tried to up the size of bars and modified various spacing parameters in the "Reinforcement Pattern" menu. This is my first experience designing RC Walls.
How might I go about changing the width over which the edge reinforcement is required so that it no longer coincides with openings in the wall?
