RC column design required reinforcement
TSOFA
Message 1 of 8
TSOFA
I try to understand how robot is calculating the reinforcement for the columns (and beams). I did a test, using 1m tall column 600X600mm. I applied at the top of the column some loads and then run the calculation at the required reinforcement module. I can't understand what kind of reinforcement distribution is the robot considers . Does Robot calculates bi axial moment or calculates the reinforcement for each side of column and then adds them? At my test model for bending moment equal along each side (My=Mz=200kNm), the required reinforcement is not the same along b and along h side (why?) There is also some small difference if I apply the moment along the one axis each time (DL4- only My, DL5- only Mz). What is the right working flow? first we must run the required reinforcement, decide the reinforcement that we will use and after apply this reinforcement to solve again the column with provided reinforcement module?
Replies (7)
Message 2 of 8
TSOFA
Are there any verification examples ( simple column design by hand and by robot) available?
Message 3 of 8
teixeiranh
What code regulamentation are you using?
Here is an example:
“The most powerful force on the universe is compound interest.”
Subscribe me on Youtube:
https://www.youtube.com/channel/UC6G8OOp318Z1MFzJj5T8uWw
Message 4 of 8
TSOFA
I am using Eurocode 2
Message 5 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
I'd suggest looking at the cprresponding Help topic first:
http://help.autodesk.com/cloudhelp/2015/ENU/Robot/files/GUID-84324591-17D9-460E-AF1E-DBD2AF363F8C.ht...
It is.
The amount of required reinforcement is based on the equilibrium forces in the cross section and you should run the design of reinforcement entering the list of all combinations you want to include in this process. There is no need to use the required reinforcement module first - you can go directly to the provided one.
Artur Kosakowski
Message 6 of 8
TSOFA
thanks a lot 🙂
Message 7 of 8
TSOFA
thanks!!
Message 8 of 8
genieyas
Could some one explain to me this topics
http://help.autodesk.com/view/RSAPRO/2015/ENU/?guid=GUID-84324591-17D9-460E-AF1E-DBD2AF363F8C
I can't understand because robobat gives me the total area of rienforcement and not As1, As2 As3 and As4 as shown in the topics (i know for symitrical raisons, As1=As2 and As3=As4); i use BAEL91 (Frensh standard), is ACI318 gives
the values of each side einforcement AS1,......
Sincerly
Another question: Whay the corner rebars are cumputed with AS1=AS2 and not As3=AS4
Sincerly
