rc column design not importing design cases
memoalcr
memoalcr
Please help. I don't understand why the RC Design module does not consider manually defined ULS cases for design.
I select the column > robot shows the right list of combinations in the parameters for RC elements windows > but the loads window only shows 3 ULS cases (see attached files)
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @memoalcr
Switch off the indicated option > calculate the model > import the combinations again
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
