RC beam Tapered bars - problem with self weight
Rafacascudo
Mentor Mentor
Rafacascudo
1-Single bar - no problem
2-Single bar with tapered RC beam section already assigned and then divided at intersecting nodes - no problem
3-Sequence of bars assigned with another (regular) section and then I assign them to be that RC beam tapered section (bar SEQUENCE)  - Self weight is not generated.
4-BUT if I assign the tapered RC beam section to EACH bar of the sequence , then self weight will be generated
Tapered steel sections not affected by this problem.
I tried manually inserting the generated superbar into the load table but it is refused.
Any ideas??
thx!
Rafael Medeiros
Artur.Kosakowski
Autodesk Support
Autodesk Support
Thank you for notifying us about this situation. We will investigate why this doesn't work as intended. For now use the 3rd method please Smiley Happy
Artur Kosakowski
