RC Beam - Required versus Provided
Hello.
Observing the reinforcement area for bending - diagrams - we can see the elevate difference between required and provided reinforcement area. But if I change the diameter manually, it's ok. So why does Robot use such elevate ratio?
Camila.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi Camila,
Could you attach the file with this beam (please indicate which beam number to look at in case there are more than one in the model) so that I could have a closer look at it?
Artur Kosakowski
Sure!
Thanks for your attention!
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Is it because it was told to? Smiley Wink
Artur Kosakowski
Thanks a lot! I'm still learning and I didn't saw this detail. Thanks!
