RC beam design
RC beam design
azad.krantz
Message 1 of 13
RC beam design
azad.krantz
I've a inverted U beam that I must use in a project but I cannot find ways to define this RC section in RSA. Is it even possible?
Also, is it possible to design this type of RC beam using the RC design module in any way?
Here is a screenshot of the beam:
Replies (12)
Message 2 of 13
Simau
Hi @azad.krantz
You may design it as a T Beam
M. Agayr
Message 3 of 13
azad.krantz
Isn't match the shape like I needed, as you can see in the attached image, the beam is shown as a T, I want to design U-RC beam with going with 4 grade slope at the middle of the beam.
azadkrantz_0-1727766084372.pngazadkrantz_1-1727766390705.pngazadkrantz_2-1727766413602.png
Message 4 of 13
Simau
You may create it using: Tools > Section definition
M. Agayr
Message 5 of 13
azad.krantz
How to create a slope in the upper edge and in the middle of the beam so that the lower edge is without slope?
Message 6 of 13
Simau
Split your bar into several pieces with variable height.
Don't worry about the shape because what matters is the mechanical characteristics
M. Agayr
Message 7 of 13
azad.krantz
How should I split the beam at different points to get the following shape and get the correct calculation result?
Message 8 of 13
Simau
First you must create a dummy beam in your model. Select this beam and split it using:
Then apply these created section at each part in the model
M. Agayr
Message 9 of 13
azad.krantz
With this, the shape of the beam will change completely! Also, we will not reach the goal we designed.
The height of our beam start with 400 mm and it will reach 2800 mm in the middle (The highest point) of the beam and it will return to 400 mm at the end.
(Please pay attention to the attached pictures and then answer the questions.)
Message 10 of 13
Simau
If you are interested in the results and not in the shape, you have 2 solutions:
M. Agayr
Message 11 of 13
DennisVDijk
Hallo Azad,
See picture:
I think you should check the reinforcement manually based on the beam forces.
Kind regards,
Dennis van Dijk
Structural engineer
www.ibureaunoordwolde.nl
Message 12 of 13
azad.krantz
Hallo Dennis.
I want to design a beam whose lower edge is a vertex and the upper edge has a slope. This model that you suggested will have a slope at the top and bottom of beam.
As you can see in the attached image, I designed the beam using Idea Statica software.
Unfortunately, the robot software is incomplete and full of bugs....
Message 13 of 13
DennisVDijk
good luck with your project!
Kind regards,
Dennis van Dijk
Structural engineer
